I need some help figuring out the value of the diode right above the location of D281, it was completely destoryed.
https://drive.google.com/open?id=0B9iJtowEdJmTTkVhX2hNVVlacVJ5Z0J6SnBBQUJjQ01TemYw
Thanks for any help you can give
Are there any other diodes in the amp that are identical? If so, lift a leg and probe it with volt meter on diode setting. One thing nice about amplifiers that mirror L/R sides with identical componentry. Most often, engineers seem to like using the same parts whenever/wherever possible, especially if they are getting huge bulk discounts in prices.
In some cases, you might be able to replace it with a slightly stronger diode, especially if they updated that section later on in revised builds.
