Hifi Line arrys
Hi Ralf
There were some good JBL line source designs in the late 70´s
wich are adaptable to hifi use, I have the design papers, will look them up and scan.
The next step would be a planar wave source, bigger but even more fun, i´ve got a nice design You can have.
I'm currently at the design stage with a speaker inspired by the Infinity IRS. 😀
I plan to use 5 Peerless 12" XLS per speaker, mated to the B&G RD-75. The crossover point will probably be slightly below the point at which the bass array begins to comb (between 200Hz and 300Hz), and will be the highest order I can get away with in the digital domain, to improve the effective power handling of the RD-75.
Any thoughts?
BTW I'd like to thank the Bush administration for driving the dollar/sterling rate into the 'it would be stupid not to buy at US prices' range😉
array design
as i read the white paper i think its not possible to use 14 pieces of 5" (13cm) bass midrange, and 16 pieces of silk dome tweeters, when i want to crossover them at 4500hz with 1st order (6DB)?!!!
the thing is, that i would prefer 1st order crossocer.
Do you think it will work?
thera are silk dome tweeters in a case of 5 to 5 cm wilh a 2,8cm silk dome in it. Perhaps i can use them??
thanks,
Ralf
I also just replied to your message...
I have very little experience at this, however, most of the good tweeters are going to recommend a second order cross. Perhaps this is only a method of protection, but then, that's a really good reason all on it's own.
