First, thanks for the opportunity to speak, and second, I apologize if this has been discussed previously (I searched).
I have purchased Kef Q55.2 loudspeakers and blown the drivers twice. On the first occasion, I was driving them with an Onkyo TX-SV444 receiver with the volume at about 11:00. I know...I think I learned my lesson on clean power and after getting a replacement speaker, I moved to a Carver HR752 receiver that I borrowed from a friend. Guess what. With the volume at about 10:00-10:30, I blew a driver again.
This time, I have been informed by the dealer that I must move to a more substantial power source - a dedicated amplifier - and therefore separates. The theory was backed by his demonstration of my speakers connected to his MCINTOSH setup and running my speakers at a volume that I could not imagine was possible for any loudspeaker for about 10 minutes.
It is my fault for not understanding the Kef requirements better and the dealer's fault for not asking what I was driving them with. But in the end, I am looking at a serious outlay of cash to solve the problem. Am I headed in the right direction, or are the Kefs just the wrong speaker for me?
I will answer all questions and will appreciate any help/suggestions.
Lamepops
Lamepops
Hmmm. Even a POS Carver receiver shouldn't be blowing drivers at any sort of humanly tolerable volume level unless there is something wrong with the receiver. Your chances of having two receivers broken in the same way seems a bit unlikely.
Were you listening to the same source (CD player, tape machine, etc.) when the drivers blew? Is it possible that your source is putting out some ultrasonic crap that is going through your receiver and into the speakers? Which driver (woofer, mid, tweeter) blew? If your source has a problem, when you bring home that new, expensive amplifier (did he try to sell you some $500 cables to go with it? Those KEFs are pretty particular about cables, too
) you're going to have the same problem.
Check your sources and if they look OK, check the amplifiers. If you have access to an oscilloscope you can see what is happening at the output. Large DC offset (anything >100mV or so) at the output of the amp indicates a problem. If the offset goes to just a few volts it could blow a woofer, depending on how the crossover is wired in the speaker. Ultrasonics would kill tweeters and maybe midranges.
As to listening to to your audio dealer who says you MUST go to separate components... HAH! If your dealer really cared about YOU, he'd be trying to figure out what's wrong with your system, not trying to sell you more junk. If we all listened to our dealers we'd all have $100k+ systems (complete with mpingo disks and CD demagnetizers), and our dealers would all drive Lamborghini's to work. Why do you suppose an audio dealer would tell you to buy more equipment- it couldn't be because he wants to get into your pants (specifically, the pocket where you carry your wallet) is it?
The speakers don't require any special electronics to drive them. If you took them apart you'd find a crossover and coil and magnet drivers just like 99% of all the other speakers out there. The impedance of the speakers is going to be about the same as 99% of all speakers. They are designed to present a benign load to almost any amplifier (though I'll admit anything but a resistor is asking a Carver to work awfully hard).
MR
MR
Just a suggestion, till you find the source of your problems get an inline fuse attached to your pos terminal. A 1 amp fuse should do it. It won't help the sound having that attached but it could save your drivers. Talk to somebody about getting a fuse or circuit breaker built into your xover untill this is all figured out. My speaks have fuses and I have blown them 3 times using high powered SS.
Kefs - cont'd
Thanks MR, I know this is a DIY site, but I'm a bit desparate.
1) On you first questions, yes - same source, a CD. In one case, it was Phil Collins which I know is a fairly dynamic recording. In the other case - Puddle of Mud. And yes, I was playing them fairly loud, but not as loud as I have cranked the Advents and certainly nowehere near as loud as what I heard through the MCINTOSH setup (yikes).
2) On cables...I have a set of Monster Cables (not sure about AWG - but guessing about 12) and I definitely checked phase - RED to RED, BLACK to BLACK (not bi-wired, and about 10ft in matched lengths).
3) The driver that is being blown is the Uni-Q driver - a combined tweeter and midrange. In both cases it sounded like everything above 100 Hz was gone.
In fact I do have access to an oscilloscope, and that sounds like a fairly easy thing to check out. So if everything is ok, I should see an AC signal with very little DC offset. If the DC offset increases with volume, then there is definitely an issue, right?
Sound like there is more to the story.
Maybe a solution is hidden in the answers to the questions below.
1) Which driver was being getting damaged, tweeter, woofer, or mid?
2) What was the source device, CD, tape, turntable, etc?
3) What was the source material, Rap, rock, orchestral, fusion etc?
4) How did you have the tone controls set? Do you have a Graphic equaliser?
5) Is there a second set of speakers hooked up to the Speaker B output?
6) What type of speaker cable are you using?
7) How long is the speaker cable?
8) A trickier area: How are the componts powered? Are you using a power strip? Is the system powered from 2 different AC wall plates?
Let us know, maybe the forum can suggest some fixes.
Aud_Mot
Aud_Mot
If you can check with a scope, do so. Other thing to notice, are there any strong HF sources around. It looks like you might have HF getting in the amp and to the speakers. A DC ofset might be, but less likely as you blow the high/mid.
Other thing to try: if you have a pc with soundcard and a bit of soft, you could connect that to your output (through a suitable attenuator) and use your pc as a real-time (audio) spectrum analyser, that would make it easy to spot HF breakthrough.
To Aud_Mot - Replies, and thanks for your time
Lamepops: The combined tweeter/mid, everything above about 100 Hz (I think this is the Uni-Q driver).
Lamepops: CD in both cases
Lamepops: Phil Collins in one case, Puddle of Mud (Rock) in the other
Lamepops: No equalizer. Tone controls - first time set at treble +20% and bass flat. Second time (using Carver) both flat.
Lamepops: No
Lamepops: Monster Cable, 10-12 AWG
Lamepops: 10 ft
Lamepops: Receiver plugged into wall plate, CD player plugged into Receiver's outlet.
Aud_Mot
Lamepops: No
Lamepops: 10 ft
Aud_Mot
Thank you Havoc
Interesting that you mention HF. That reminds me that there is a digital cable receiver running off the same outlet for the television.
Could it be?
I have picked up some of that rf noise while playing my guitar in that room and eliminated it by turning off the tv and cable box. Could that same rf energy find its way into my stereo???
Could it be?
Could be that...
Another thing which I thought of and is the reason I have become disenchanted with Kef's in recent years is the complex x/overs they use on some of their speakers with uni-Q drivers. These can be a notorious load (low imp & capacitive/inductive) for some amps to drive, thus causing them to clip momentarily even at medium vol levels which could also be the cause...
tomcat
tomcat
I'm not familiar with your paricular Kef speakers, but I have seen some dip as low as 2ohms at certain frequencies. Manufacturers can be tricky in quoting impedance and other parameters of their products, so that a notional 6ohm rated speaker is only an average over the frequency spectrum. In reality they can be closer to 3 to 4ohms in the critical areas where the amp really has to find power to drive them. Of course for this reason impedance plots usually are only found in reviews not manufacturers literature...
cheers,
tomcat
cheers,
tomcat
Since you were using your CD player in both instances, I would look there. Maybe some clock bleedthrough to the output is managing to get through the amp causing your tweeter to fry.
No the cables won't matter. No the type of music won't matter.
Try taking your CD player into the shop where the guy wants to sell you a new amp and hook it up to play through their amp. Crank the volume to the previously used unbelievable level and see if the speakers blow.
DC at the output of the amp is definitely a bad thing, but not likely to blow a tweeter unless the crossover is pretty weird (or has a shorted capacitor). The other thing that can blow a tweeter is distortion caused by driving the amp output to the rails (hence the suggestion to use a high owered amp), and oscillation (sonic or ultrasonic).
I have seen Carver amps driven to oscillation by connecting weird loads to them (in my case, electrostatic speakers). I don't know about Onkyo stuff, but I suspect it is likely to be a bit better designed than Carver. It is doubtful that the speaker presents an especially difficult load.
MR
MR
Lamepops,
Because you have had the same problem with 2 different receivers, I doubt it is some esotreric electronics interface problem.
Everything from here seems OK. But, If I were in your position I would try:
Get a filtered power strip. Plug the strip into the wall and then plug all your devices into the strip. Never use the receiver's power outlet.
Make sure you get a power strip that has true noise filtering and not just "spike protection." The ones with filtering will also have spike protection. These are the ones with chokes (coils) and caps to filter out noise. The ones with true noise filtering typically make a big deal about it on their packages. Available from many sources, electronic stores, computer stores, mail order.
You can pay thousands of dollars for these things, you don't need to do that. Probably in the $20 - $50 range will be good.
If this does not work, you won'y be wasting your money. This is a good installation practive anyway.
Regards,
Aud_Mot
Regards,
Aud_Mot
treble +20% ????
treble +20% ???
Thats what is killing your tweaters. You have to listen your music with no tone controls, beter to say FLAAT OK. I have been trough this many years ago.
One more time, keep your tone control FLAAAAT.
With icreased treble control, and as well with volume increased voltage on your tweater will rise nonlineary and at one point will
jump to the level which is more than enugh to overheat the coil of
the tweater and that's it. puuffff.
Happy music.
treble +20% ???
Happy music.
Thanks everyone!
I bought these speakers new, and the dealer has replaced both blown speakers with no hesitation, so I am going to try to stick with them and implement some of the changes that have been suggested.
I am convinced that the AC power filter and much improved power source will make a difference. Even if I don't end keeping these speakers, I will have a good amp and enhanced knowledge thanks to you guys.
Have a great weekend!
Stop the insanity!
Something is broken and needs to be fixed.
Special line cords, filters, wood pucks, directional cables, and other pieces of audio-voodoo are not the answer. You may as well pray for the problem to fix itself- it's cheap, but considering the state the world is in after thousands of years of millions of people praying, you're probably better off trying science.
Some clear-headed, logical thinking and a little experimentation will reveal the source of the problem. Did the same channel blow a driver both times, or has it happened in both channels?
Check for DC and/or oscillation coming from the power amps (let the system warm up before testing). If that isn't the problem, then try using another CD player- a portable, a boom box, or whatever. The method is to try to trace the problem from the speakers back through the system, eliminating possibilities as you go. The very LAST thing to even consider looking at is the freakin' power line!
I'm beginning to remember why I let my Stereophile subscription lapse...
Re: treble +20% ????
If everything above 100Hz is gone...
something isn't adding up...
a/ you have a sub?
b/ that means you are taking out both the midbass & the tweeter (the UniQ XO is at about 2kHz)... really hard to do. DC could take out the midbass. heavy clipping could take out the T.
And having two different amps do the same thing is wierd... i don't know about current models but Onkyos from the late 70s, early 80s were pretty good, and Carvers were really bad.
I wonder if there is a breaker or fuse in the XO that is tripping?
dave
a/ you have a sub?
dave
- HiFi Hell..please help with Kefs
