Hi, pair of Mark Audio MS 11s on there way to me, looking for a wide baffle design for them, any ideas?
Or something like this .
By tweaking the SIM, I get Twenty-One liters worth of internal volume, at -3.07Db@43.22 Hz, (fb 47 Hz.)...perhaps this would be a candidate for the 2001 Monolith dimensions?, 1-4-9 ...
---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------Rick...
You're welcome!
Install Hornresp, download/Import the attached Record and and all the information required to make it other than driver cutout size, bracing plus various performance sims.
No, if a cube it's only ~10 1/3" o.d. square using ~3/4" (1.8-9 cm), though better to make it a golden or acoustic ratio, then make the supra baffle as big as you want with the box mounted on the rear. Also, a good plan to offset the driver/box at a golden or acoustic ratio on both x, y axis to average out its eigenmodes.
