Hi DIy experts
I need help to build 2.1 channel Amp.
i have zero knowledge of electronic. just started after i found lots of Newbie got success in it.
I have already purchased
1>Wintek - 200W Mono (2SA1943 / 2SC5200) W/o Heat Sink
2>Wintek - 68W Mono (LM3886) W/o Heat Sink
for 1 Wintek-200W Sub AMP (Power supply: 2 x 30-42VDC / 520-720VA)
and for 1 Wintek-68W-Mono-(LM3886) AMP(Power supply: +/- 20 - 35VDC / 190-230VA) (68W cont. avg. output power into 4 ohms at VCC = +/-28V)
-->The above details are only for single AMP
For Wintek 200 watt i am confuse should i go with 30vdc or 42 vdc or 36VDC will be good to produce 200watt @ 8 Ohm ? and transformer power ?
For 2 Wintek-68W-Mono-(LM3886) Transformer power ?
Currently i have 24-0-24 @5A can i use it to feed 2 LM3886
Br
Ved
Br
Ved
