With these speakers there`s only one way to go; bi-amp the speakers, bypass the original bass-filters and run the basses through some active filters. Everything else is like beating a dead horse, it won`t run anyway. Use the forum to get some cheap & good stuff.
this speaker is a known amp killer.
but my 40watt Mirand still sounded better..
no my friend.the speaker ahave awesome bass but it is almost impossible to drive it.
first look at the back to use normal mode and not extended.
what kind of amp are you using?
yes, it is
yet, I have experienced a cheap NAD driving it, with ok result
but one of the few, as he has burned several other amps
he is now driving them with older Nakamichi, and no problems at all
a bit of a surprise as I didnt even know if it would survive the test
but yeah, it got hot when activating the EQ function
a bit frightening with only one pair output devices![]()
but it worked, and sounded very very nice
he had never heard them play that good before, or after
but I understand there are two Kappa 9 models ?
btw, I think the woofers were replaced, as the surround had rotted away
Have they maybe been repaired ?
sou stelno p.m.you had this loudspeaker?
i have a tube amp,magnat,but i dont dare to use it with this killers,i have also a yamaha 2000
eisai ellinas?
exeis tilefono spiti?na ta poume apo ekei?
yiannis
