Hi
I have a 1305 based cd player on which one channel recently started distorting. To the extent that it's completely unlistenable. The 1305 is a simple all-in-one solution and is easy to observe the output directly at the chip pins. Even when the o/p is not connected to any external components the distortion persists. So my question is whether this means the 1305 is faulty or is there any point to extend the troubleshooting to the WS clock. I am pretty clueless about the relationship between the clocks anyway so pointers will be much appreciated. Any remaining sources of tda1305?
cheers
PeterK
cheers
PeterK
Please send your address to me.
I mail ONE piece to you.
No need to charge.
I work in PHILXXX semiconductors.
Regards,
nFORCE
No need to charge.
Regards,
nFORCE
Many thanks for your kind offer nFORCE. Your profile doesn't allow messaging and hides email. Could you pls contact me at
free_mnet@yahoo.com.
best regards
best regards
Unfortunately it is my turn now to look for one, some 3 years too late.
Anyone know any reliable sources at afordable prices ?
Thanks,
Patrick
Thanks,
Patrick
John,
One minimum, two would be nice (as long as they don't cost an arm and a leg).
Can arrange bank transfer to your a/c in HK. Used to live in To Kwa Wan. You could email me direct if you wish :
ybpkwan@web.de
Thanks in advance,
Patrick
ybpkwan@web.de
Thanks in advance,
Patrick
furore & mace
This is completely off topic and I apologize to the rest of the members.
nForce, from your post, I understand that you work for Philips Semicondctors. I am forced to post here as you do not have your e-mail button enabled.
Is it possible for your to source the Furore chip and mace chips for the SACD 1000. I am in need of replacements. Would appreciate it if you could send me a personal mail at jdg2@streamyx.com
Regards,
JD Goonting
Regards,
JD Goonting
Hello all
I also need 2 tda1305. Does anyone know a place where I can buy them? I searched and searched but without results. It seems that some members here know or have some. I would be grateful if someone here could help.
I have a Micromega stage 3 cd player and there is distortion in 1 channel...
Thanks in advance
George
Thanks in advance
George
Re: Re: Help with TDA1305
I will send you full number if you can.
Can you help me? I need one SAA73xx.nFORCE said:Please send your address to me.
No need to charge.
Regards,
nFORCE
- Digital Source
- Help with TDA1305
