Help with Pan XR45 / DCX2496 configuration
I'm stumped about how I should configure the XR45 as a 6-channel amp behind a Behringer DCX2496.
The inputs on the amp (not mentioned in the manual) are:
CTR - LS - LF
SUB - RS - RF
As for speaker level outputs, I have left/right front and surround as well as center. But my sixth output is "back".
How do I get a signal into the receiver and routed out "back."
Thanks.
Digging up old post....
I have same set-up (like Newform) XR45 & DCX2496 where the XR45 Front and Surround is used as 4-channel amps, driving 2-way diy speaker with the Behringer XO.
I am now thinking about the possibility to have separate amplification for the woofers which in my case has XO at 100Hz, by means of using CTR or SUB + for example Hypex.
If so, I would use 2 channel sub sum by the DCX and the woofer would run Mono but since XO is quite low it might work. Then, I could use mid and tweeter 2-way and the system would "almost" be three way system.
Anyone has any comment on that idea?
LageB
