While cleaning out the garage, I came across a matching pair of woofers and tweeters, seemingly used in an older two-way design (the tweeter had a simple first order tacked on, I assume the woofer was run full range or some animal took a liking to the coils...
Matching pairs...
Numbers on the woofer:
49-1319
6Ohm
A-ONK
KOREA
1304
Numbers on the tweeter:
49-1307
8Ohm
A-ONK
KOREA
1332
Does anybody have any idea where these drivers may have come from, and maybe (its probably too much to ask..) the T/S on them? And if you don't know, is there somewhere else I should ask? Thanks in advance!!
Matching pairs...
49-1319
6Ohm
A-ONK
KOREA
1304
49-1307
8Ohm
A-ONK
KOREA
1332
Actually they sound suprisingly good, for what looks to be cheaper drivers. (But I don't have much experience with older stuff, who knows.) They sure don't sound like anything I've heard recently from Radio Shack! Gobs of good sounding (read: clean, not deep) bass from a relatively low excursion driver (9v test bumps it about 4mm), and a sparkling treble I don't usually associate with cone tweeters.
I asked my dad, who's speakers they seem to have come out of, and he said that he thought they came from a pair of Zenith Allegro 100's, does that help anybody?
re: qwad
I actually thought they were Onkyo myself, just because they said "ONK" and that's what popped into my head
re: Nappylady
I was actually thinking about trying some OB's with them, as I love the OB sound, and w/o the T/S, its fairly impossible to put them in a suitable BR or sealed enclosure. How big is big? would a half-sheet of 1/2" MDF each be ok? (I have an extra laying around, bought it thinking it was 3/4"
re: Nappylady
Half sheet will start the dipole rolloff around 300hz, so use with a subwoofer is probably a really good idea. (That's a 4'x4' piece, right?)
You could probably turn these into a killer 3-way really easily. And if you went active, I bet you could really get killer performance out of them.
Congratulations on a great find!
Roll-off around 300hz you say? (yes, it would be a 4'x4' peice)
That seems awful high to run a "subwoofer"....but I do like the idea of turning this into a 3-way! With it being a 6" midwoofer, what would you suggest for the bass? And it gets plenty loud and sounds rather good with a Sonic Impact T-amp off baffle...and I have a plethora of the little things! I might look into building an active crossover and doing just what you suggest -- going active!
Thanks for all the help!
My 3-way PA system uses Parts Express #290-380, which is a Goldwood 10" PA woofer. It's inexpensive, and plays very nicely in a 2cuft box tuned to 40hz. (Make sure you use a BIG port or vent.) I cross over at 200hz, but anywhere up to 500hz should be just fine. They can play very loud, but they also play very clean at low volumes.
This looks like a very exciting project! I hope it goes well for you. Keep us updated...
- help with older drivers...
