Hi looking for 2x TK15A60U n-ch mosfets for a lg tv power supply or an equivalent mossfet that would do ?
foud 2 on digikey but they workout expensive with postage looking for a common equivalent if possible
It is in the power supply and a safety critical component by default. If you are confident you have repaired the fault that caused them to fail, bite the bullet and purchase the correct ones. Near equivalents will not do!
+1
Meets or exceeds specs will probably be just as expensive so just get the exact part and there won't be any question.
