Hi everyone,
This is my first 3 way build! But have build other speakers before.. I tend to go all out when I do projects and I need help designing my cross over!!
In total there are 5 drivers per speaker (all Dayton Audio).
Tweeter: 1x (RS28F-4 1-1/8" Silk Dome Tweeter 4 ohm)
Mid Range: 1x (RS125-8 5" Reference Woofer 8ohm)
1x (RS150-8 6" Reference Woofer 8ohm)
Woofer: 2x (RS180-8 7" Reference Woofer 8ohm)
My set up is to run the Mids in parralel, for a load of 4ohms... And the same for the Woofers, for a load of 4ohms! In result, it will end up with 3 loads of 4ohms...
I was wondering what you guys suggest I put the crossover points at? I was thinking 500/4000hz. I was thinking this way, the mids will not be playing anything that they are not intended for, and still have room for some signal that gets through, and will not distorte! The bass will be tight, and not overly loud, since I plan on building a subwoofer in the future to go with the set. And the tweeter is well able to play down to 1200hz... So I have no worries for the tweeter capabilities! Any ways...
What type of crossover do you recomend? And at what crossover points would be optimal for this design?
Please comment and tell me what you think!!!
