I made this amplifier but i couldn't find the tip140. instead ibought the tip142 becouse is equivalent, but the amplifier doesn´t work.
Can anyone gives me an advice please, i have spended a lot of time on this project.
original page
I have made the pcb with wincircuit2000
Here it is posted:
original page
Here it is posted:
I wouldn't call it very good, it can be improved in quite a few ways fairly easily.
The output resistors are labelled wrong. They should be 0.47 ohm not 47 ohm. Also the 10 ohm at the output should be 0.1 ohm.
I can't figure what the 270 ohm 1W + 47uF 40V cap is doing.
None of those things should stop it from working though, just make the output very quiet.
tady said:tnx for the reply.
hmmm... what are they used for? current generator?
can this amp be used for a 1 ohm speaker?maybe if i use different transistors?
NO.
I can't think of any amplifier that can drive a 1 ohm load with any reliability.
- General Interest
- Car Audio
- help with 260w rms amplifier
