Hello,
I’m just about to start my first two OB builds this weekend (hurrah), and am hoping for some help on a couple of what should be quick and easy questions for you guys. Your advice would be much appreciated / and allow me to get a flying start!
Cheers.
Keith
I’ve seen builds with the Full Range Driver and the Bass Driver being on the same vertical centre-line, and on other builds the Full range driver is offset to the side slightly.
Tweeter / Full Range is Fostex FE-88 SOL
Bass is JBL 12” 123a.
Baffle size will be 1200mm tall x 600mm wide, but have 2 x 1200mm x 300mm wings to add if needed. Thought it wuld be a good lace to start without having to do too much reading (a bit like the Glow In The Dark Builds).
Is there any accepted / best way of doing this: in line or offset?
Also, I can’t find any builds which show the height of the of the driver off the floor. I understand lower is good, but would you go for 100mm? 150mm etc
Any advice / help and suggestions would be much appreciated.
Cheers.
Keith
Cheers.
Keith
Cheers.
Keith
