Hi All,
Background:
I have built what I was hoping would be an elegant (simple) speaker, based around a Supravox 215 2000 full range.
This is mounted in a fairly small open baffle giving an acoustic high pass around 250 Hz. Supporting this is a tweeter above 10K, and a 15" woofer in a sealed 130L box.
They are running passive at the moment, with the bass (Re 8.9 ohms) on the end of a 5 MH inductor, with an impedance correction accross the drivers. The Tweeter has a single capacitor, and the Supravox has an broad notch filter for baffle correction.
My biggest problem is the efficiency difference between the full range, tweeter and the bass. The Supravox is rated at around 99 db, the tweeter at 94 db, and the bass (JBL K145 variant) at 96 db. In practice however, I have had to pad both the full range and the tweeter down by close to 6db in order to get a flat response.
Proposed Solution:
I like to keep things simple, and what I was thinking of doing (at least initially) was:
Questions:
Sorry if some of these questions are niave, or if this has all been asked before!
Thanks for your time and thoughts
David
Background:
Proposed Solution:
- keep the bass impedance correction, full range baffle correction, and tweeter hi pass as passive;
- double up my amps as a biamp setup, with one amplifier on the bass, and one on the full range and tweeter;
- boost the bass by 6 db relative to the full range/tweeter (or cut the other by 6 db);
- put the 1st order lo pass before the bass amp;
- maybe put something before the full range amp to cut the lowest bass.
Questions:
- Can I do the above passively before the 2 power amps - i.e. split the signal from my preamp and use a resistor pad to lower the full range amp output, and an inductor to do the bass 1st order lo pass?
- Am I much better to add gain? Why?
- Do I need to use buffering - to isolate the two signals?
- Is there a really simple solution for thsi that even a novice like me can apply?
David
Seems like I have asked for too much, I will rephrase my question.
Can I integrate a simple active crossover into a twin power amp.
I am thinking of running the preamp output into a OPA627 (at unity gain) with a 1st order roll of below 80 Hz to drive my OB full range & tweeter, and a OPA637 with 6 db (or possibly variable) gain and a 1st order roll off above 250 Hz.
As I am looking to put these within the twin power amp box, I am looking to do this without any buffering.
David
David
Hi Decathro, you may get a better response in the multiway forum, but do a search on PLLXO (passive line level crossover) and I think you should get the answers to at least some of your questions.
Not something I have done but certainly something that has been done by others successfully
check out Passive Line-Level Crossover
Tony.
Tony.
