I'm trying to solve a problem on power amp board of a Sansui AU-D5 after I did a full recap. The protector circuit does not allow the signal to the speakers. When I measure the voltage on terminal 95 and 100 in the attached drawing, with volume knob on minimum, I get -31 volts? Further on I measure almost the same negative voltages close to 30volts at the base of transistors Q11-15....
I'm not too experienced on this area and wonder if someone can tell me what could cause this unbalance? Thanks in advance.
