HELP! New sub design!
Well, I ordered a blueprint 1503 and 2 adire PR15's but have yet to come up with a design. I am assuming that i am going to have to mass load the PRs pretty heavily. Blueprint suggests a 4cuft box tuned to 16hz. How large should the box be and how heavy should the PR go? Someone please help! I do not want to screw this up!
Linkwitz Transform
If you want low bass that's incredibly tight and fast, build a small sealed box and use a Linkwitz Transform circuit to simulate the perfect sealed box. If you have plenty of watts, this would be a great alternative to passive radiators. The more mass you add to passive radiators, the slower the bass becomes. This iwlll already be a problem because of yhe high excursion of the driver. But the sealed box will counteract this.
