Help needed biassing electrocompaniet eci-4
Hi everybody,
after fixing My output transistors i need some help biassing the beast.
Schould bias be set when the amp is cold?(13mVcurrent)
When the amp is hot i cannot keep bias under 13 mv,even with potmeters closed.
Should i let the bias climb to stabelise afterwords?
How high current is safe to not damage the output stage.
Thanks for any help
