HELP: Nakamichi CA-7 Volume Gear Parts
Hey Guys,
I'm looking for the gear wheels for the Nakamichi CA-7 volume motor, (Think its the same for most CA pre's) due to its age, the parts as been broken off. please find the attached part numbers.
i need the parts:
08 (must) - 0J05232B
13 (if available)
17 (if available)
does anyone know where i can find such ? or any mods ? :)
TIA
its been some time, but i finally manage to fix it using cheap gear whees assortment off eBay :) just 5 bucks. posting here so it might help some one else.
the broken parts
new worm gear in place to match with the rest of the gears
new gears in place
complete drive shaft
https://scontent.fcmb1-1.fna.fbcdn....=471537e8c8b70ff56e865bc9f4568f1c&oe=5ACBAE3D
clutch need some work to get the new gear in
after some work
https://scontent.fcmb1-1.fna.fbcdn....=0612adca9155b1c44c93956f25acefc5&oe=5ACD2442
new gear meets the clutch
all done!
Dear Kalinga, I found your thread as I have a similar worm gear issue with my CA7E. (The part ‘08’ has disintegrated basically). Your links don’t seem to be working anymore and I wondered if you could help me source the parts that you found so I can get my motorised volume control working again!! Thanks so much, Jim
