Help me understand Bastanis wiring
I am interested in building speakers based on the Bastanis Prometheus. They have no crossover to speak of, and I don't understand what keeps the bass info from the tweeter, which is wired directly from the other driver( Eminence Beta 12 cx coaxial with Beyma tweeter). Here's the schematic http://www.bastanis.com/diy/prometheus+mkii+build.htm
Eminence calls for a 3.5k crossover with the coax and their own suggested tweeter. Thanks
what makes you think it´s the 12CX from Eminence?
Looking at the datasheets and the FR in particular I´d guess it´s more like the Delta12LF. (at least for the Prometheus MAXX which has a paper dustcap)
There´s cap in series with the tweeter, isn´t there?
greets & let us know how it turns out
PS.: I reckon you did see their forum:
http://www.audioasylum.com/forums/bastanis/bbs.html
Look at the datasheets of the 12CX and Delta12LF.
There is a jump of almost 10dB at ~800Hz in the fr of the CX
whereas the Delta is kinda smooth until 2k.
Then comes a little hump that should be negligible (or easy to tame with a 6dB-high-pass).
If you want to further investigate I could send you an article about the Prometheus MAXX with fr-responses of the fullrangers used (the fr´s look very similar to the Delta12LF here as well) and everything else.
greets
