Hey all! I'm looking to build myself a good pair of headphones, and would like some speaker advice. I assure you all that I am fully capable of doing this.
I'm looking for some speakers that will provide the best bass possible (For stoner music), while still being reasonably small (2.5" max) and not incredibly deep (40mm deep max).
Now, my old pair of headphones has a 20Hz to 20kHz frequency range, but it's got some cheapo 1 1/2" electrostatic speakers. At least, I think that's what they're called. They're the speakers you find in all kinds of electronics, including heaphones, with the very thin plastic membrane that crinkles if you touch it (by accident, of course).
Old pair of headphones:
BEHRINGER: HPM1000
I can't find a spec sheet on them, sorry. But the speaker is labelled as follows:
L. S
040-029
32ohm
My question is: If I get a normal type of loudspeaker with a lower range of frequency response, is it possible to get better bass?
I'm still searching for a good one, but a bit of searching has so far yielded one (maybe) suitable result:
Peerless 830985 2-1/2" Full Range Woofer | Parts-Express.com
The frequency response only goes down to 90 Hz, but the frequency vs SPL curve seems like it's acceptable down to around 70.
What do you think? Can you recommend something better?
BEHRINGER: HPM1000
L. S
040-029
32ohm
