help in aikido for sennheiser hd580
I want to build an Aikido based on this shematic New LV-Regulator 6n1p / ecc99,
I have a pair in stock 6n1p-ev and i want use ecc99 or 6h30 to output tube, which one is the best tube I am more ecc99 turned out to be a cheaper tube. Recently broskie modified the typology of the pcbs Aikido PP & Solid-State Circlotron, I can use the above scheme but with two-voltage resistor divider or am I mistaken?
I was thinking construct a PS retfier tube with valve eh 5u4gb or GZ34 or others ... will be a good investment in terms of sound quality or 4 simple diodes play well in it?
I have read that some use the PS Salas with good results...
Intend to use new manufatoring tubes not old nos stock, my current headphones are sennheiser hd580.
That much confusion in my head 😕 initially wanted to build a botlehead crack but octal tubes how good are rare and expensive, and then I went to aikido which I think is much better sound than the crack or not???
sory my confusion and my bad english 😛
