Hello all,
I have the following parts for sale that were all previously used for making a gainclone (based around the LM3886)
The more you can take off me in one go the more I'll drop prices as I'm trying to clear this stuff out.
Aluminium heatsink (large) - £3
This is in good condition but has 11 holes drilled into it
Length: 270mm
Width: 200mm
Height: 25mm
Aluminium heatsink (small) - £1
This does have thermal paste on the back and 6 holes drilled into it
Length: 200mm
Width: 80mm
Height: 25mm
Project box with rubber feet - £5
ABS Plastic case with two metal plates either end. One plate has 3 small holes and 1 larger hole. The base of the case has 1 hole drilled.
Length: 280mm
Width: 195mm
Height: 75mm
Capacitors
4x 10,000uF (63 volt) (snap in) - £5
12x 470uF (63 volt) - £2
2x 1000uF (40 volt) - 50p
8x 100uF (50 volt) - 50p
Bridge recitifers
2x 8 amp inline 240 volt - 50p
2x belived to be 6 amp, 240 volt - 50p
Resistors
8x 0.05 ohm - £3
Misc:
IEC (kettle lead / PC) style plug with matching socket - £1
Smart Kit 5014 - 3 channel wireless light effect unit - £4
- already constructed and in the supplied casing. Just needs an electret microphone wiring onto it
Full details can be found here:
http://quasarelectronics.co.uk/smart-kit/1014-3-channel-wireless-music-to-light-effect-230vac.htm
Length: 270mm
Width: 200mm
Height: 25mm
Length: 200mm
Width: 80mm
Height: 25mm
Length: 280mm
Width: 195mm
Height: 75mm
Capacitors
Bridge recitifers
Resistors
8x 0.05 ohm - £3
Misc:
UPDATE
Here's what's left... Any takers?
Bridge recitifers
Resistors
8x 0.05 ohm - £3
Misc:
Bridge recitifers
Resistors
8x 0.05 ohm - £3
Misc:
[/B][/QUOTE]- Status
