Just got a Heathkit IP-17 power supply.
I will use it to put together small "flea power" tubes amps for fun, tear them down and put together another one with a different small type of tube, etc...
Now on the Heathkit power supply, on the front, there is the + and "common" high voltage outlets for the amp circuit.
Also there is a Ground one by itself, should I tie the ground to the "common" outlet of the heathkit?
Since the "breadboard" will be an old tube amp chassis, should I use the Heathkit ground for the chassis ground?
I dont mind soldering and unsolderings the parts on the chassis and using it as the negative/ground of the circuit. Would be more solidly tied together since I might listen to the test amp for a while on 2 sets of speaker in two different rooms.
Also, I might fool around with some preamp circuit.
So in fact, my "experiment" circuit would be: the B+ , and the chassis on the negative/ground from the Heathkit.
Should I install a fuse on that chassis?
Just like a normal tube amp.
But then, if the Heathkit only has a two prongs AC plug for the 120 Volt from the main (didn't received it yet). Should I install a 3 prong AC plug?
Kind of funny, but I love to fool around with tubes amps, but I'm pretty scare of these high voltages, hence all these questions...
What would be the best way to go about it.
Any suggestions, ideas, objections?
P.S. I already built/restored a few Tube amps: 300B SE. Dynaco ST-70, ST-35, TubelabSSE, restored a Fisher 500C and a pair of QuadII.
Search the forum for this, didn't find much.
Type of circuit I'm looking at:
