Headphone amp power supply problem
How to use an output cap to protect the amp/headphone?
Wire it in series with the headphones, it blocks any DC. Value depends on headphone impedance.
What happen if one of the 9V battery dies if thete is no protection circuit?
I reckon you'd notice it sounding distorted first and turn it off. Its definitely a problem if you've powered the amp up, with cans connected but aren't listening, then the remaining battery could cook your headphones' voice coils.
@rayma's proposal is the best one - don't use a 'balanced' supply (i.e. plus/minus 9V) rather use two batteries in series to give 18V, with caps at in and out. Then you'll avoid the problem and not need any protection circuit.
For DC offset, it won't be an issue since I am going to implement dc servo. But those op amp I am going to use are dual power supply op amp, can't be drived with 18V.
So, the conclusion is, I still need a protection circuit, right??
Your DC offset servo won't work properly when one battery goes down.
I'm only aware of one opamp that needs a ground pin, so chances are you're going to be fine with your opamp choice running on a single supply, provided you bias your audio symmetrically between those two potentials - i.e. around +9V - with some kind of supply splitting circuit.
So no, you don't yet need a protection circuit.
The easiest way is to use capacitors (AC coupling). Capacitors has audio marks and larger capacitors are less distortion.
In fact, with the phones under 100ohm I have tried, the poor quality 2200uF capacitors (from China) have also achieved good results, although the sound is reduced in a little more detail.
A cap in series with the output jack? What should be the value and type??
