I bought a Dayton pre made cabinet for my center channel. All I need to do is drill the circles for the mids and tweeter. I have read a lot about how a plunge router is the best way of going upon this, so I bought one this weekend for $40. I'm only going to use it for this center channel, and sometime down the road for my two rears. I didnt' need to spend between $100-200.
anyways, now that I have the router, what do I need now? Do i absolutely need a Jasper circle jig? What kind of bit do I use?
any help would be very appreciated. thanks!
I'm assuming you're in Brandon, Manitoba?
try here, located in Winnipeg:
http://www.mach5audio.com/index-4.html
PoorSound said:Do I have any other options?
Not much of a problem to make a circle guide. This being a DIY site, it's kinda appropriate.
I use the router (with a straight cutting bit) to cut the driver recess. I cut the hole for the driver with a jigsaw. Faster, cheaper (no burned out router bits) and a lot less dust.
PoorSound said:anyways, now that I have the router, what do I need now? Do i absolutely need a Jasper circle jig?
It takes about fifteen minutes to make a circle jig out of a 1/4" plywood scrap and under 60 seconds to add a new radius. Draw a few radiuses from the center of your router before you drill out the center hole and pick a different one when your pivot holes would over-lap.
You can have any size you want (I built a 12' jig) with increments finer than the jasper jig's
Spiral up-cut if you're going to veneer later for better chip extraction. Spiral down-cut when you need to prevent tear-out (make multiple shallow passes). Straight bits for cutting rabbets.
Jasper makes good jigs as long as the base plate fits your plunge router.
The 1/16th inch resolution is generally good enough, but I've found a few drivers and cases where it wasn't.
The hole created by a router can be much prettier than a jig saw cut. But then who cares, you aren't going to see the fine imperfections and you can always sand them smooth.
I still like to go almost all the way through with the router for the final pass.
PoorSound said:I bought a Dayton pre made cabinet for my center channel. All I need to do is drill the circles for the mids and tweeter. I have read a lot about how a plunge router is the best way of going upon this, so I bought one this weekend for $40. I'm only going to use it for this center channel, and sometime down the road for my two rears. I didnt' need to spend between $100-200.
Where in G-d's name did you get one for just $40?
Daveis said:Jasper makes good jigs as long as the base plate fits your plunge router.
My problem with the Jasper jig is that it requires you to use a 1/4" cutting bit(not the shank), to make all those cuts work properly. And since I always use a 3/4" bit I ocassionally forget and then make a total mess. you would think I would learn my lesson but I don't. Must be getting old.
I have no idea as to why they think we will use such a small bit. It's just not logical IMO.
- Have a plunge router...now what do I need?
