Hashimoto PT ratings
Joined 2015
I don't understand the DC rating for some of the Hashimoto power transformers for full-wave center tapped rectification.
PT-150 for example, is rated at "280V-250V-220V-0-220V-250V-280V: 0.16A AC (220mA DC with Full Wave Rectifier)"
For FWCT, shouldn't the DC rating be derated 1-1.2X from the AC rating?
Another example, the PT-300B, which is specified for bridge rectifier, seems closer to my expectation as DC is derated by about 1.6.: "20V-0-280V-310V-350V: 0.53A (330mA DC with Bridge Rectifier)"
Hard to interpret the manufacturers specs, perhaps 2 eras, or perhaps 2 product engineers.
If you use a center tapped secondary, and 2 diodes in full wave, the current in each 1/2 of the secondary is on for one alternation; it is not on for the whole cycle (two alternations).
A bridge across the whole winding is on for the whole cycle (two alternations).
And, a tube rectifier's voltage drop versus current (that is resistance, even if dynamic), reduces the peak current to a cap input filter; versus solid state diodes.
However, I do know that if you use a Choke Input filter, you can always get more current out with the same thermal rise of the windings, versus using a Capacitor input filter.
True, the DC voltage only approaches 0.9 of the ACV for choke input filter;
versus the DC voltage which approaches 1.414 of the ACV for cap input filter.
Right, that aligns with my thinking.
PT-150: 280V-250V-220V-0-220V-250V-280V: 0.16A AC (220mA DC)
PT-180: 280V-250V-0-250V-280V: 0.22A AC (300mA DC)
For an EL84 P-P, I assume around 175-180mA is needed for B+ winding.
If I trust the DC rating, then PT-150 should be sufficient....otherwise need the PT-180.
After all other tradeoffs are considered and accounted for, you will never be disappointed if the transformer runs cooler.
But I have a power transformer that never runs cooler, there just are not enough primary turns and laminations. It runs hot, because the manufacturer was cheap.
