It seem like GC chip amps and Class T amps are gaining popularity. Has anyone compared the sonic differences between the two types?
Hi!
I went from cheap trannie amp to valve amp to chip amp to 41hz AMP3. The AMP3 is by far the best one so far - much more detail and clarity, without any harshness. The only minor drawback so far (still experimenting, with no 'special' components and without a proper PSU yet) is a slight lack of bottom-end bass (or maybe it is just accurate, and not 'overblown' ?).
Just my tuppence-worth! 🙂
Jim
Jim
Beelzebub said:Hi!
Jim
Did your chip amp have a good PSU?
Large VA trannie, high-current bridge, large smoothing caps (30,000uf) with bypass caps (200uf) and smaller caps close to the pins (10uf and 0.1uf). Everything in the PSU was well over-specced, so regulation and current handling should be no problem. I didn't go for a regulator chip, as I wanted to keep it simple.
