Hello,
I recently acquired a Harmon Kardon Citation 16 power amp. I would like to set the offset voltage and idle current. Anybody out there have a schematic handy?
Thanks,
Craig
Thanks,
Craig
you should have +- 10 milivolts at the output when the amp is cold and with no load.
You adjust that by the VR1 pot
The bias should be set to 10 milivolts between the speaker terminal (the red one) and the resistance that is behind the output (remove the small cover) .Adjust with VR2
