The 930 is known for a loud pop after turn on, however, the particular unit on my bench keeps on popping for a few minutes after.
I first pulled the Main-In/Pre-Out jumpers and fed a signal directly into the amp. Other than the typical HK initial pop, there were no further eruptions. So the amp section would seem to be ok.
With the function switch set to Aux 1, I measured the voltage at the output (R) of the Tone Control PCB while also measuring it at the speaker output (R). I chose Aux 1 because this bypasses the Preamp board, making the Tone Control board the only board between the RCA input and the Preamp Out. Here's what I measured:
Initial Turn On
Tone Control: quickly fluctuating voltage as high as 1.4V DC.
Speaker: quickly fluctuating voltage as high as 19V DC.
First Three Minutes
Tone Control: voltage settling down to between 600mV and 700mV
Speaker: voltage still going as high as 2 - 3V, but beginning to drop to 150mV in tandem with the output of the Tone Control board.
After 10 Minutes
Tone Control: voltage fairly steady at 465mV
Speaker: voltage staying at around 115mV (still high for DC offset, so I'll likely replace the differential pairs to see if I can lower it)
Power Down
Speaker: spike of 16V or so, gradually dissipating.
I'm thinking there's either a leaky cap or a bad transistor on the Tone Control board. Maybe more likely a transistor since the issue seems to disappear after warm up. Unfortunately, the service manual doesn't include any reference voltages to measure against, which is how I would usually track down the offending component. While I can hit each transistor with a quick shot of freeze spray, I'd like to hear how others would suggest narrowing down the possibilities.
Initial Turn On
First Three Minutes
After 10 Minutes
Power Down
