i did not find any rules for the PT and OPT orientation on a top and down position. all the rules of thumb on here are applicable to side by side or single plane placement (which goes by 90deg out in the core orientation). im in a position where i need to stack the OPT right above the PT on dual plane.
although 90deg placement of the core is still observed, is there anything else i need to watch for? the OPT is hammond 1650R (above) and PT (custom) is about 280VA. they are practically resting on each other with a heavy gauge (2mm) plate in between. any problems here?
thks for any help.
thks for any help.
