Bob, I assume you dont have an original manual for the amp. DH200s were sold in the US with 120 60hz transformers with an optional (extra cost upgrade) of a multi tapped multi voltage trans. If you have the multi tap, it will be obvious when looking a the trans. There is a schematic on it w/ the combos of voltages (100,120,200,200,or 240 50/60 hz) A schematic in the manual shows the different wiring options depending on the voltage used. I would have attached it but my scanner is dead. Do you plan on buying a new 220 trans? If so, I can scan the schematic at a friends and post it.
good luck, taylor
