I succumbed and purchased a new Hakko 951, the old Hakko works fine but I need two soldering stations, one workshop in OH the other NJ.
A bit disappointed upon first setting up so as a repeated error message S-E appeared and the iron wouldn't heat. A quick call to Hakko and their tech support provided the info.
Turns out that the new tips take a while to seat themselves properly. You have to insert and remove the tip a few times and the error is resolved. The tips themselves have protective sleeves so you don't burn your fingers. On the first occasion the tech suggested removing the protective sleeve.
Hakko provides a heat-protective mat for you to twiddle with the tips and get them seated properly. See picture.
None of this is in the instructions which come with the station. I suppose that there are some product liability issues with 750F tips that they don't want to open up.
The soldering station works great! It has a sleep function which saves some watts. The tip gets to temperature in just a few seconds when removed from the holder.
