I'm finally taking the plunge and building an RIAA preamp from schematics, and after some research I've arrived at Jim Hagerman's octal version of his Cornet. While I have a few years of experience fixing tube gear and building packaged kits, I've never undertaken a project starting with just schematics and a parts bill, so this should be a fun challenge.
Because the PCB is no longer available, this build will be constructed point to point (not turret board). I'm currently working on ordering parts and have a few questions...I'm hoping some of you that have experience building it can chime in:
1. Other than the CCS on the output, are there any changes/improvements made in the Cornet ver. 2 that I should implement in this design? Can I use the same component values for the CCS circuit on the 6SN7?
2. What coupling capacitors would work well for this preamp that don't break the bank?
3. Do you have any tips for proper grounding and silent operation, or do you know some resources I should look at before I start?
4. Anything else I should know?
Thanks in advance for the help.
Schemos:
Cornet octal
Cornet 2
Schemos:
Cornet octal
Cornet 2
