Once I made a Condenser Microphone preamp using two BC549 transistor. Now I've built a preamp with LM358. It sound is neither too good nor too bad.
I saw many people to make preamp using LM741 and TL072.
Now my question is
1> my primary aim to connect the preamp with a acoustic guitar pickup. I want very good audio quality. And I'll also buy a good pickup. Which preamp circuit will I use?
2> the duty of preamp is to amplify the gain. So in this term, guitar preamp, tape head preamp, microphone preamp all they are same. is it right??
3>Will I need any special preamp for guitar pick up
T h a n k Y o u
T H E O
Now my question is
T h a n k Y o u
T H E O
Paswa said:Hi,
Now my question is
T h a n k Y o u
T H E O
Hi.
The preamps are similar, but not exactly the same because of noise issues, filtering, and other needs.
Modern op-amps, such as the OPA134 may be a better choice for you.
Even the older NE5534.
Say You have am amp that needs 1V for full power on the output.
Say Your pre-amp can only 500mV. What gives ? Only half the power.
Now Your amp needs 500mV but Your pre can 1V. You will clip the amp, but wait ....You a have a volume / gain pot for that on the amp input.
Guitar pickups have usually very high impedance (MegaOhm), so a JFET op-amp is a good choice, but as Your guitars have pre-amps built in, they probably have low impedance output.
You have to make sure that output impedance is always lower than the amp input impedance (impedance bridging) or You will get that thin sound.
On the other way, mikes have low impedance, so every op-amp should work with them.
To answer Your question... Pre-amps are all basically the same but ...Gain differs between types, but for Tape & Phono for example You need equalization networks and more gain. For Mikes gain is similar, but for a Tuner or CD player or even Your Guitar perhaps You don't need high gain. That's why mixers have gain pots and tone controls.
And Yes they should work with any "normal" amp. Bear in mind that some PA intended amps need a higher voltage on the input say 2V, compared to consumer mV levels.
What kind of pickup are you considering - magnetic soundhole pickup, piezo bridge pickup or internal microphone?1> my primary aim to connect the preamp with a acoustic guitar pickup.
The majority of acoustic guitar pickups come with preamps - you'll see their small control panels situated on the top or side of the guitar.
If the pickup doesn’t have a preamp, it can be plugged into any acoustic amplifier, DI / mixing desk or preamp pedal.
An excellent guitar preamp design is one of the most difficult in audio. You cannot just provide clean, flat, quiet gain----it may sound terrific for a phono cartridge, a microphone, or a tape head but it will sound TERRIBLE for a guitar. Guitars don't want clean or flat. Perhaps one of the best, most affordable guitar preamps is the Joyo American pedal. If you want to build your own, I suggest an emulation of that.
This is extremely unusual for electric guitars. There were a some electric guitars with active pickups (which contain preamps) in the 1980s, but very few today. Bass guitars frequently have built-in preamps, but basses aren't guitars.The specs for my guitars say they all have preamps.
Are you perhaps talking about electro-acoustic guitars, as Galu suggested? Those are very different things, and the requirements for an acoustic guitar amp and preamp are very different, compared to electric guitars.
Can you tell us more about your guitars? What makes and models are you referring to? As Galu said, what sort of pickups are in them? If you give us that information, it will be easier to answer your other questions.
By the way, the LM3886 is ancient in electronics terms: it dates from the late 1990s, about twenty years ago. (Note that this thread dates from 2008, eleven years ago!)
The LM3886 is a fine example of a class AB integrated circuit power amplifier chip from the last century, but this type of amplifier requires a huge, heavy, and expensive heatsink, and lots of clean DC from its power supply.
Because high-powered class AB chip amps have to get rid of a lot of heat through a small area of metal (the chip is very small), they are really not very good choices for amplifying musical instruments - they tend to have poor reliability when driven hard.
For a power amp in a little guitar practice amp, these days I would suggest using one of the many class D amplifier boards available on Ebay, Amazon, etc. These are much more efficient than the venerable LM3886, so they don't need a huge heatsink, and they draw less power from the power supply. Many of these newer class D chips also operate in bridge mode, and that means they also need less supply voltage, which makes it easier to find a suitable power supply.
-Gnobuddy
Jings, I hadn't noticed that and was referring to the original poster!Note that this thread dates from 2008, eleven years ago!
I was thinking the same thing at first, but I think Galu may have successfully read Jimbo724's mind, and figured out what he didn't actually say: Jimbo might be talking about acoustic guitars, or rather, electro-acoustic guitars, i.e. acoustic guitars with onboard piezo or mic pickups and onboard preamps.You cannot just provide clean, flat, quiet gain----it may sound terrific for a phono cartridge, a microphone, or a tape head but it will sound TERRIBLE for a guitar.
If this is the case, a flat-response preamp and speaker system are fine. There will probably be at least three bands of EQ built into the guitar, which will be sufficient for tweaking the sound for non-critical situations. Usually the output level is closer to mic level than line level, so a fair amount of voltage gain might be needed.
IMO it's really nice to have more sophisticated EQ available to take away some of that stinging treble and too-deep bass that electro-acoustic guitars are notorious for, but that is a whole other kettle of fish. I've used a cheap little Danelectro Fish and Chips graphic EQ pedal do do this job; it isn't manufactured currently, but there are somewhat similar graphic EQ pedals available online.
-Gnobuddy
Noise optimization is totally different depending on the source impedance and like MAAC0 wrote, tape head preamps have built-in equalization filters. By the way, an LM358 is about the worst op-amp available for audio applications.
The post you are replying to is from 2008, and the poster also talked about audio preamps using the LM741 op-amp.By the way, an LM358 is about the worst op-amp available for audio applications.
I see that the LM358 datasheet has no noise specification (just like the Jurassic-era LM741), and large-signal response falls away above 5 kHz, suggesting a very limited slew rate. Still, surely an an LM358 can't be as bad for audio as the LM741?
-Gnobuddy
'358 is typically a hair better than '741.
In low-level work, especially at low impedance, the one that really sucks is a '324. Anything over 50uA load it throws a big glitch in the wave. Heavy NFB can only do so much. I had cobbled-up a buffer just before a show, and it sounded bad. I re-read the sheet, saw my screw-up, but the quickest fix was to throw 470r pull-down so it would drive 600r in class A. Ate the battery but it was not a long show.
I've used '358 for something, forget what. It can be OK for many uses. The big deal is that, among 1970s chips, the supply current is low. Of course far better chips are made today. But '358 persists in guitar pedals of vintage design, and I'd use it there if nothing better was at hand.
Gnobuddy,
One guitar is a Luna electric-acoustic. The description on the Guitar Center web site says it has "Luna's SL3 preamp system with a built-in tuner."
The other guitar is an Epiphone Limited Edition Les Paul Traditional PRO-II. The pickups are passive humbuckers; an Alnico Classic PRO at the neck and an Epiphone ProBucker-3 at the bridge. "You can also pull up on the bridge pickup’s tone knob for an additional 15 dB boost. The active Boost control is powered by a 9-volt battery, which is easily accessible at the back of body."
I want to build a DIY guitar amp. Has any particular chip widely replaced the LM3886 or are there a gazillion options?
What sort of guitar amp? Clean (acoustic), vintage, rock, high-gain ?I want to build a DIY guitar amp. Has any particular chip widely replaced the LM3886 or are there a gazillion options?
If you don't know the answer, have a listen to some of the samples on Runoff Groove (for simple solid state stuff) or the Ceriatone (for valve options) websites.
Note that at least 1/4 of your "tone" comes from the speaker.
As far as I know, the LM324 and LM358 are exactly the same circuit with the same horrible class-C output stage, except that the LM324 is a quadruple and the LM358 a dual version.
Blues rock, variable distortion/crunch.
I'll check out those web sites. Thx.
...LM324 and LM358 are exactly the same circuit...
Ah, you are quite correct. I was thinking of some other number and being mixed-up.
So I will amend to say the '324 is twice as bad as the '358. (Twice as many amps inside.)
If that is REALLY what you are after, you MUST use tube circuitry----no solid state amp is going to do that well. The only possible exception to that rule is the various Roland amplifiers which all use proprietary digital modeling techniques that are not available to us DIYers......I want to build a DIY guitar amp. Has any particular chip widely replaced the LM3886 or are there a gazillion options? ........Blues rock, variable distortion/crunch.
I agree with dotneck335.
Getting great distorted guitar sounds out of ss technology is possible, but a lot more difficult than with tube technology.
I highly recommend the BYOC champlifier kit.
Great clean to mid gain distortion guitar sounds in spades.
- Live Sound
- Instruments and Amps
- Guitar Preamp = MIC Preamp = other preamp ,,are they all same?
