Is there any reason to run a ground lead from the platter bearing to the same ground as the tonearm? My Roksan makes a bad attempt at it, and even when fixed, only connects the bearing to the arm mount. The mount is insulated from the arm itself, so it is not connected to the tonearm ground (different to signal ground). Is there any reason to ground the bearing at all, either separately or by joining it to the arm ground?
