My first time wiring up an amp and would appreciate some advice on the safe approach.
The TPA and SMPS are mounted side by sideon a plywood base with a plexiglass cover. There is also a iec plug with switch and fuse. How should I connect the grounds (from the IEC plug, the SMPS power supply, and the ground wire from the balanced input of the amp... there is also a shield wire on the neutrik XLR connector)
Thanks!
JD
Thanks!
JD
