Hi folks,need help by some project that Im on in this days.I have become some tube power amp that uses for input tube a ecc83 and for output a pair of EL84 pro chanel.So now I have thinking to use some Dact stepped attenuator 2x100kOhm that I have at home and put this in front of the ecc83 tubes,so I could attenuate the volume of this little tube amp.For now in the original design there where a first in series input capacitor of 0,015uF than in paralel the grid leak resistor of 1Mohm and than in series the grid stopper of 47Kohm.So I have decide to omited the capacitor and grid leak resistor becouse I will use the stteped attenuator.IS this ok in this design???But I m now thinking of the grid stopp resistor,what for value I must use if I use the 100Kohm stteped attenuator on input that the frequency response still will be OK in the range of 20Khz.
Plese for some help,becouse Im a little new in this tube hifi stuf.
