Great Investment For Someone.
Tried?
Have you tried odering a custom one off toroid?
Even Plitron will try to discourage you from doing so as it is NOT cost effective.
I tried to order two 1.5KVA with 65v secondaries from them last year and they didn't even want to consider it, they have 60v and although not listed, 70v as standards so I opted for the 70v.
I know this mackine will not do anything that big but it would be nice to have the facility to wind your own toroids if you build a lot of power supplies etc.
Cores are cheap and easy to get but that dosnt make this particular winding machine any good as it does not do thicker wire than 1.6 or so. The ones that can deal with thicker wire are a lot bigger and quite pricey.
Anything below 1.6mm wire can be found custom wound for little money in most countries.
Magura🙂
Metal shortage is a serious issue theese days. The price for scap steel reflects that in particular. Its been increasing by a factor 15 here during the last year or so...scary that is. The same story goes for pretty much any other construction metal. Copper have been hit hard, I just bought a few spools of magnet wire, omething like 100 lb....lets put it like this, the invoice was downright scary:bigeyes:
Magura🙂
