Graph of ten Goldwood 1005 piezos
quick on-axis comparison - so far able to get three rough pairs from
a lot of 10 units. there's little consistency and response can vary quite
a bit.
Ten Goldwood 1005 1/12 octave smoothing
pairing units 8 & 10
pairing units 5 & 9
pairing units 2 & 6
units 1, 3 ,7 not matched (have to go back and compare to unit 4)
I was able to get a 4th pair out of ten
being like a 0.13uF cap, sometimes its good to have a series resistor. I've seen a problem paralleling them with a resistor and using a high pass cap - the ~4K peak can remain and a saddled response shape appear - perhaps a lot of FR setups are so rough off axis that its better to have some treble than none.
the old CTS KSN 1005 driven with a backwards wired 25 volt matching transformer and LR Zobel on the transformer's "primary" gave over 100dB at 2.8vrms and was pretty flat from 5- 20K. All of Goldwood's 1005 out of these ten look the same including the impression that the phase plug is a bit off center.
CTS KSN1016 on transformer - 1uF
For use as a tweeter, DJK has a good scheme to go with the transformer (use 8R/100uH Zobel for 0.13uF piezo)
Goldwood's 1005 knockoff graph is scary in its own right
