I have read that there are advantages to use several parallel (smaller) capacitors to replace a single bigger one in the HV filtering circuit, such as achieving lower total internal resistance etc. Would this argument also be applicable to the signal path or stage decoupling capacitors? For instance, should one use 1x0.2 uF or 10x0.02 uF? Which will be better for sound quality?
TIA.
TIA.
