Good Alternative to Guilford of Maine
I am trying to build some acoustic panels for cheepish and have found that the most expensive part is the fabric. I am building 12 2x4 foot acoustic panels (4 to 6 inches thick) with Knauf insulation. And at that scale the GoM fabric is over 500 to cover it. I am looking for recommendations for a cheeper fabric that will look almost as good and keep the insulation in. The Isolation and fabric is linked below. Also if you recommend a different insolation that will do a better job of broad band absorption i am open to that to.
Insolation:
https://www.gikacoustics.com/product/knauf-rigid-fiberglass-1-6-lb/
Fabric:
https://www.gikacoustics.com/product/guilford-of-maine-fabric-by-the-yard/
The bass traps in the corners and the one over the window are burlap covered 4" Rockwood in wood frames.
Go to a local fabric store and buy whatever they have that’s the color you’re after. I suspect there will be something that will work wonderfully.
The fabric is there mainly to hold the rock wool/fiberglass into the frame, as long as you don't use something like nylon sailcloth, (with a tight, fine weave and made to hold air…) whatever you find is going to do the job perfectly.
Reactions: mr ed
I am trying to build some acoustic panels for cheepish and have found that the most expensive part is the fabric. I am looking for recommendations for a cheeper fabric that will look almost as good and keep the insulation in.
Rockwool is cheap, and Duvetyn or commando cloth is farly cheap. I haven't used it specifically for absorbers, but I would expect the lighter weights would work well for it and it has a fire rating.
https://www.rosebrand.com/subcategory151/fabric-by-type-commando-cloth-duvetyn.aspx
