Im going to invest in a new scope and a bench model is preferred but i can also think of something like the picoscope if the performance is better. My budget is around $300-600 but i can stretch a bit if its going to give me a better performance.
It will be used mostly in audio circuits, power supply, for both development and troubleshooting.
One really important function for me is FFT with a good resolution.
I will do comparisons between different transistors and transformers in the signal path and want to do measurements on frequency response.
The display should be quite good. 2 quality channels is needed. Don’t think i will be doing digital circuits but you never know.
Here are some options that came up when doing research:
Rigol DS1054Z
DS1054Z 50 MHz Digital Oscilloscope | Rigol - Beyond Measure
Tektronix TBS1032B
TBS1032B Tektronix | Mouser
Uni-T UTD2052CEX
Digital Storage Oscilloscopes-UNI-T
PicoScope 4262
https://www.picotech.com/oscilloscope/4262/picoscope-4262-overview
Lecroy Waveace2002 (this one has a 20% discount right now on ELFA)
https://www.elfa.se/en/oscilloscope...1+-+162170&page=18&origPageSize=50&simi=97.12
If you have some experience of the models i listed or you have some other options i would be glad if you want to share.
I rather pay a little more and have something i can use for years.
What is the advantage having a signal generator built into the scope compared to using an external one?
Rigol DS1054Z
Tektronix TBS1032B
Uni-T UTD2052CEX
PicoScope 4262
So you hope to run audio-grade THD and noise measurements with the FFT function?One really important function for me is FFT with a good resolution. I will do comparisons between different transistors and transformers in the signal path and want to do measurements on frequency response.
Samuel
Samuel
I was hoping to but maybe thats out of my price range. From what my research tells me the cheaper scopes are not that great for FFT measurements. Any recommendations? Would the picoscope give me more value for the money here?
maybe the QA401 (fairly simple plug and play) for the analysis and a 100MHz analogue scope to see the waveforms.
Thanks! Interesting, have you used it? I will def look up this piece. Would you recommend an analog scope for audio waveforms?
I was waiting for the QA405 but they brought out the 401. It is available in the USA and should become world wide soon.Thanks! Interesting, have you used it? I will def look up this piece. Would you recommend an analog scope for audio waveforms?
I think they are checking to see if it needs debugging in any way before going world wide. Software can be updated at any time and seems to be an ongoing development.
I got the Rigol DS1054Z upon recommendation of Salas last year. Has served me well (with my limited experience).![]()
Thanks have read a lot of good things about it. Just don't know how usable the FFT function in it is for audio.
Maybe an Rigol DS1054Z + QA401. Or maybe an analog scope?
Looks like they ship to Sweden
I have this combo. Actually QA400. Not much you can't do with these two.Thanks have read a lot of good things about it. Just don't know how usable the FFT function in it is for audio.
Sent from my Nexus 7 using Tapatalk
No money will buy you a scope with decent audio-analysis capabilitis (for scopes, more money mostly means more bandwidth). It's simply the wrong tool for this.I was hoping to but maybe thats out of my price range. From what my research tells me the cheaper scopes are not that great for FFT measurements. Any recommendations? Would the picoscope give me more value for the money here?
Samuel
Looks like a great combo, and not that expensive.
Samuel
Thanks for the advice, thinking of buying the QA401.
If i go with the Rigol also has this version:
DS1074Z-S 70 MHz Digital Oscilloscope | Rigol - Beyond Measure
It has a built in signal generator, but i don't know if its worth twice the money.
I need a quality signal generator but i can only find really expensive ones...
Although i have a quality sound card ~$2500..
I think you are in the wrong price range for good FFT. I think it's better if you get a good sound card to begin with. You'll need 16 bit or more and how many reasonably priced scopes have that?
Samuel is right, you'll need an Audio Precision (or similar). The best spectrum analyzer can't handle audio very well either.
Okay i have the Apogee Ensemble TB, really nice. But dont think i can use it for measurements?
Gw Instek DSO-2000E series.... The FFT it is very good at the affordable prices. Oscilloscopes - Digital Storage Oscilloscopes - Digital Storage Oscilloscope, GDS-2000E - Digital oscilloscopes,Digital storage oscilloscope-GW Instek
Looking good, but expensive.
See e.g. Rightmark for a possible software package, and e.g. http://www.diyaudio.com/forums/tubes-valves/155405-test-measurement-interface-soundcard.html for an analyzer front-end (not strictly necessary, but recommended).Okay I have the Apogee Ensemble TB, really nice. But I don't think I can use it for measurements?
Samuel
Samuel
Thanks, will look into it. Have many options to research now.
- Design & Build
- Equipment & Tools
- Gonna buy a new oscilloscope, which one to buy?
