I have a Golden Age Pre 73 Preamp that I would like to do something different with. I have 4 Seven Circle N72s so I have the Neve sound covered. What I am considering doing is upgrading the input and output transformers, changing all of the transistors to germanium, adding a PAD switch, and a "thick" switch(light low end boost). What I would really like is a Chandler Limited Germanium Pre but that's a lot of money and no where near as fun.
I know how to upgrade the Transformers and I think I can figure out the transistors. How would I make a PAD and Low Boost switch? Where would I need to insert those in the circuit?
Also would changing the transistors to germanium make any difference? The only reason I thought I would do that is because that's what the Chandler uses.
