Hi folks, does anyone have somewhere in archive Giaime Ugliano Maida regulator schematic, pcb drawing and pcb layout. I remember that this scheme was simple and easay and i need it for one testing, but unfortunately Giaime-s site (http://giaime.altervista.org/) where the info was is down.
Thanks in advance.
Thanks in advance.
Thanks for quick reply, I already did, only found a bad quality pcb pic. For late projects I have used tomchr maida - which was superb, but components are in my country hard to get. That's why I remembered and tought that it will be easy for quick solution to use Giaimei's stuff.
I've found http://www.diyaudio.com/forums/tubes-valves/205175-maida-regulator-pcb.html here,
also if you go to http://web.archive.org/web/20120119210546/http://giaime.altervista.org/maida.html
you can at least see the parts used, although no more pics
Could you ask Tom here http://www.diyaudio.com/forums/tubes-valves/209067-21st-century-maida-regulator.html
Pretty sure I have the original schematic (on my home computer)...
I also built the Maida regulator a few years back to power an Aikido line stage.
When you are interested you can have it (fully working of course).
Otherwise I can send you the schematic (and my own how I built it.)
- Power Supplies
- Giaime Ugliano Maida regulator
