Does anyone know where I can get a replacement gain pot for a T20001BD. Im not sure of the designator. Im not sure if its bad or just needs cleaned, because it scatches and pops turned back and forth. It also pops when you push in on the pot, Solder joints look ok, but may need a closer inspection from me. Maybe I can blow it out with some canned air then spray some deoxit onto it.
If the deoxit doesn't clean it sufficiently, call PacParts to get a replacement. Have the board in front of you. They'll likely want the board number, the model and the circuit board designation.
