Looking at getting a T amp with the tk2050 chip to drive my next design - looking at the Helder hifi pcb's and also the Hifimediy dac (AD1853), to run off batteries.
Does anyone have one of these little fellas rigged up? How do they sound with full range units?
It's been about a year but my first experience with full rangers was a pair of Sachiko double mouth back loaded horns with some slightly modified Fostex 206Es in them. I think I tried every amp I had available including a Sonic Impact T-Amp (3wpc?) I'm a fan of the way the T-Amps can sound with the right speaker and this combination did not disappoint. I did NOT push it to find it's limits but felt that said limits were probably well beyond the comfortable listening levels in my room. YMMV
Yep, I'll second that. Had mine on quite loud the other day, so loud my friends arriving(student accommodation) could hear it when they were outside and I think in their car. I didn't realise this as there is so little distortion(and the dial was only on 2'o'clock). I'm running a commercial t-amp with Ta2024c chip inside, with some temporary mini open baffles using Fe103e's and a sub. Mine has 10w at 8ohms.
Sound is pretty good, even with my old cabinets I were using, which had many floors, people when round would ask me about them.
The full range drive units I'm using are only 85dB/1m so I won't get away with the lower power T amps unfortunately so it looks like I will use an amp with the tk2050 chip. I would like to fit a tube( in the outputs?) but know nothing about how to do this.
I'm really liking my Sure TPA3123 with my FH3's Sure 2x25W @ 4 Ohm TPA3123 Class-D Audio Amplifier Board
I might add, I'm only running it at 12V (SMPS).
I like my t amps... have the SI original, the Dayton clone and the 50 watt Dayton.
Dayton Audio DTA-100a Class-T Digital Amplifier 50 WPC Provides Power To Computer Speakers, Bookshelf Speakers, Headphones, And More!
For whatever reason i seem to prefer the cheaper amps. With the expensive Dayton the channel balance is off at low volumes but evens out when louder. It's a bit annoying. The cheapies are perfect for what they are.
People say they lack bass but i always hook up a powered sub of some kind and let these amazing little amps sing with efficient full rangers.
Zilla
Zilla
Nice thread. I didn't feel like starting a whole new one just for this question:
I'm putting a FR and t-amp setup together for my sister. The budget for the amp is around $200.
It seems like there is a jungle of potential candidate t-amps out there.
I'm driving CHP-70s so I need more than a TA2024 equipped one.
The Dayton doesn't take 4 ohm so that is ruled out.
Virtue, which I have, and is happy with, is way too expensive in Denmark.
I've looked at the Hlly tamp-90.
Are there other (better?) alternatives out there? No DIY please (I realise the irony of posting this here, but DIY speakers are involved, so...)
I was contemplating this - if its 25 watt per channel into 8 ohms(it doesnt say) then its worth considering. I sent them an email to clarify but havent heard back yet
Temple Audio Bantam Gold. High Quality Digital Stereo Amplifier. Made in the UK
I have a Temple Audio amp. But the normal one. Pretty good. But obviously that will sound different. I got mine for peace of mind as I wasn't sure on my electrical skills otherwise i would have built one of the kits.
Just spotted a Hlly TA2022 board on ebay for 40 quid inc shipping.. v tempted! Should be enough to run even very low sensitivity full rangers
i am using topping tp20 mk2 (with ta2020 chip) with alpair 7s in a sealed 6.2litres box on my desktop. Its still in the burn in stage (phase 2). Havent gone beyond 10 o'clock yet. In my small 10x12 room, its enough for nearfield and sounds really good. Once the break in is done, I will crank it up and see how it does.
I had the pleasure of hearing a tripath based Sure amp, a nice tube amp, and a gainclone on my full range speakers (Markaudio Alpair 10.2). I quickly preferred the gainclone. It just sounded better, fuller, more instrument separation, etc. Synergy is everything and if possible it's great to invite some friends over to your house with their amps in hand to see what works best for your particular setup.
Same 5-way binding posts as on the last pic of a Bryston i saw. One of favorites those.
dave
The Temple is nice (great review at TNT BTW) but the TAMP-90 just seems to be better build. Just look at the size of the ring transformer:
This gainclone type tube amp kit looks v cool but it comes in parts..Not sure my soldering skills up up to it.
Redvix Gain Clone Amp Intro
Its sold on ebay for just over 50 quid inc postage.
Or this built pcb gaincard power amp boards
http://shop.ebay.co.uk/i.html?_nkw=gaincard&_frs=1&_trksid=p3286.c0.m359
Properly implemented Tripath designs are amazing with fullrange speakers. Synergy and more magic.
I'd personally take a 24V powered amp with speakers of that low sensitivity. If you want ready-built then have a look at the Hifimediy TK2050 or Arjen Helder TK2050 amps.
Regarding power supply. Which 24 volt options are available? I cant find any good 24 volt options on the web.
1) battery, or can i brigde 2x12 volt?
2) smps
3) linear diy kits
2) smps
3) linear diy kits
Mean Well make really good ~24V switching supplies. There are some good examples mentioned in a few threads over at the Class-D forums.
You can very well use batteries. I recommend LFP / LiFePO4 batteries. These are available in the US at BatterySpace.com/AA Portable Power Corp. Tel: 510-525-2328 - Powerizer Battery Official Site - I'm not sure about Europe.
And a linear supply can also be built 🙂 41hz.com sell suitable DIY supplies with regulators and rectifiers - check out their PSU1 series: 41Hz Audio😛SU1-PS (Power Supply) kit or PS3: 41Hz Audio😛S3, 60V Power supply kit
There are lots of options. The Mean Well route is probably the most plug-and-play.
Are Helder and I think Hifimediy no longer doing the tk2050 amps? It looks like Helder have a replacement.. Now I'm confused as to what to get...
I'm pretty sure they're still doing them. Hifimediy T1 throught T4 are TK2050-based. They do use newer and better power stage chips (output transistors); These are half of the chipset. Still a TK2050-based design.
- Full Range
- Full range drivers and T-amps.
