FS: Tannoy ST200 Supertweeter - Walnut
A pair Tannoy ST200 in New condition, used few months. Incl. Box, all accessories. This was bought 8 months back has not been used much. I connected it for a few weeks and then removed and since then it is sitting on the shelves. I am disposing this off to arrange some funds for another project I am the original owner. This was bought new from India. I am asking for a $2000.
Recommended amplifier power: Up to 250 Watts
Continuous power handling: 135 Watts RMS (DIN IEC 268)
Sensitivity : 95dB (2.83Volts @ 1 metre)
Nominal impedance: 8 Ohms
Frequency response: To 54Hz, usable output (- 18dB) to
100kHz
Driver type: 25mm (1.00") diameter 25 micron
titanium dome, gold finish, with
neodymium magnet system.
Frequency: 14kHz, 16kHz or 18kHz adjustable
Type: 3rd order compensated high pass
Level: 89dB, 90.5dB, 92dB, 93.5dB or 95dB
adjustable
Dimensions: 150mm (6.00in)
Weight: 3.5kg (7.7lbs)
Finish: Oiled solid walnut
PayPal is the acceptable. PM me for pictures.
