FS: Peerless SLS 830667 8", PPB 830870 4", Madisound OEM 8" Woofers, LPG Tweeters
click the titles for specs...
Email me at daddyoppe(at)aol(dot)com for a quicker response.
Peerless SLS 830667 8" Woofers
Both woofers are in great condition with some slight cosmetic blemishes
$90 Shipped
Peerless PPB 830870 4" Woofers
Both woofers are in great condition with the exception that one has a 1/2" superficial cut on the dust cap (not all the way through).
$50 Shipped
LPG 26NA aluminum Dome car Tweeters w/ Flush & Hinged Mounts
The tweeters are in perfect condition. The hinged mounts are new and the flush mounts are in good shape.
$60 Shipped
Madisound Special Purchase 8" OEM Woofers
$35 Shipped
Both woofers have never been mounted and only 1 has seen a couple minutes of power. These would be a great set of midbass drivers for a door install with the high QTS & VAS values.
Specs:
8 ohm
Poly cone with textile dust cap.*
Inverted rubber surround.*
Good for sealed boxes of 0.5 cubic feet up to 1 cubic feet
33mm voice coil diameter
Flange diameter 215mm (8.5")
Cut out hole size 185mm (7.25")
Depth 86mm (3.4")
Fs 49.5Hz
Re 7.3 ohm
Qms 3.75
Qes 1.10
Qts 0.85
Vas 36.9 liters
Sd 220 cm2
BL 6.3
Cms 536.8 uM/N
Mms 19.2 g
Le 0.8mH @ 1kHz
Sensitivity 87.6dB @ 2.83V/1M
Power 50 Watt
$90 Shipped
$50 Shipped
$60 Shipped
$35 Shipped
Specs:
8 ohm
Depth 86mm (3.4")
Fs 49.5Hz
Re 7.3 ohm
Qms 3.75
Qes 1.10
Qts 0.85
Vas 36.9 liters
Sd 220 cm2
BL 6.3
Cms 536.8 uM/N
Mms 19.2 g
Le 0.8mH @ 1kHz
Power 50 Watt
NEW PRICES
$85 Shipped
$45 Shipped
$55 Shipped
$30 Shipped
$85 Shipped
$45 Shipped
$55 Shipped
$30 Shipped
