selling a great pair of Faital woofers .
drivers are in good condition .
asking $250 plus shipping.
paypal adds fees .
Nominal Specifications: Nominal Diameter: 300 mm (12 in) Overall Diameter: 316 mm (12.44 in) Bolt Circle Diameter: 298.5 mm (11.75 in) Baffle Cutout Diameter: 282.5 mm (11.12 in) Depth: 155.75 mm (6.13 in) Flange and Gasket Thickness: 12.45 mm (0.49 in) Net Weight: 5.6 Kg (12.32 lb) Shipping Box: (Single Carton Box) 350x350x200 mm (13.8x13.8x7.9 in) Shipping Weight : 6.2 Kg (13.64 lb)
Electrical Specifications: Nominal Impedance: 8 Ohm Minimum Impedance: 7.1 Ohm AES Power Handling ***: 700 W Maximum Power Handling ****: 1400 W Sensitivity (1W/1m): 97 dB Frequency Range: 50÷3150 Hz Voice Coil Diameter: 100 mm (4 in) Winding Material: Cu Former Material: Glass Fiber Winding Depth: 23 mm (0.9 in) Magnetic Gap Depth: 12 mm (0.47 in) Flux Density: 1.3 T
paypal adds fees .
