Up for sale is an used but in very good condition Dissipante 5U 500mm 10mm SILVER front panel - 3mm aluminium covers and rear panel case for diverse DIY project! THIS IS AN CUSTOMIZED DELUXE VERSION!!! PLEASE TAKE A LOOK AT PICTURES!!!
YOU GET A CUSTOMIZED CASE FOR THE PRICE OF STANDARD CASE!
More data and customization:
1x Front panel in aluminium 10mm oxidised silver 450 mm; as you can see on the pictures it has holes drilled for easy mounting of (riser panels or other stuff)
1x Rear panel in aluminium 3mm brushed and oxidized black; it has all the holes drilled already.
1x Inner base plate 400mm
4x Heatsinks 250mm oxidised black temperature coefficient 0,19 C°/W The heatsings have all the holes drilled for easy mounting of all the firstwatt series amplifiers!
2x Covers in aluminium 3mm brushed and oxidized black
Dimensions:
Width: 450mm internal 360mm
Depth: 500mm Internal height: 210 mm
Weight: 18,5 KG
This case is huge! I will include the neutrik RCA and schurter inlet! This case has all the holes UMS standard! So its a deluxe version but bigger 500mm!
For picutres please send me your email.
I paid around 450EUR for it but you can have it for 350 EUR or best offer.
Shipping to EU as it weights 19kg
Dimensions:
Weight: 18,5 KG
